Small 10" box
agarabaghi
Looking for the smallest box possible... Needs at least 6" of mounting dept for an Sundown audio SA10"
I was thinking something like
12x12x8
would be about .66cubic feet before displacement... Any clue if i could find this pre built or will i have to build a box?
Not going ported. This is in a boat, so I would build the box from mdf and seal it off with resin to water proof it from moisture.
Already have a RE SX on 1300watts in the passenger compartment in a ported box @ 34hz. Just wanted to add something small under the drivers feet for a little extra thump. Im only going to push ~360w to the SA10
Here's what I'm using, I've got one under each front seat built to house a 10" slim Kenwood or RE Audio slim
True. I have a bit more room than that. I need to measure it. I want to run the SA10, since i already bought it. It need 6" of mounting dept and my 12x12x16 box was just a bit too wide (12" side)... so i think if i do something like mentioned in the OP it should work
Mobil soundworks
W=13.25 "
H=12"
D=6.5"
Mounting depth for subwoofer is 4.25",and is perfect for Kicker CVT subs.. what it says
$41.39 with free shipping
on ebay under 10in subs.Not sure how to post link on here yet.Hope this has helped,and is about all i could find for single 10 under seat of 05 f-150.without having one made under 125 bucks my max for that small of an enclosure built.You may even be able to modify it to your needs also,????
Yea, the engine is a 350 chevy v8 putting out approx 350hp. It comes with a 100amp alt stock, and im looking at a 200amp upgrade.
Here are some pictures, ill be putting a build thread together as soon as it's done.
Cadence A7HC / JL m2150 / WetSound Syn 6 - mounted on starboard fiberglassed to the hull and then carpeted
Picture of the engine with cover off, usually there is another sun pad over it
2006 Mastercraft X1
Wakeboarding!
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
Mike Mccabe
    Jun 28, 2026
Giles
    Jun 27, 2026
