Slight Wood Split
chibahawk
oe squeezer
Ok I was putting my port piece in and when I was screwing it in with a 1.25" screw with a predrilled hole somehow it put a nice lil split into the edge.. it's not big at all but I'm wondering what you guys might suggest.
And nobody better say start from scratch - im not going to be upset with a 95% quality box build on my first attempt as it's coming out nice right now.
thanks
i squirted some glue in the part that i cracked and clamped it, works fine, i wish there was a way to elminate that shit though, its gay, i predrilled and countersunk all the holes but a few still cracked the board
Pull the screw and push glue into the crack/split, do this a few times and while the glue is wet after covering this area once or twice take some sawdust and rub it in. You can also do the same thing with the screw hole.
Predrilling only reduces splits and to help reduce them even more, don't put screws in unless they're about 4-5" away from the edge of the board. Also keep as few screws as possible per panel.
This is the second old thread about wood splitting you have bumped //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
chibahawk
oe squeezer
chibahawk
NYC
bjfish11
