Single din head units with seperate subwoofer control?
  • 1
Pkoblish
I recently picked up a boss audio single din with the flipout screen and was disappointed to find out it had no subwoofer settings. Adjusting the eq for the speakers would make my subwoofer crazy quiet. My old HU had a subwoofer level adjustment, where If I turned low frequencies off on the door speakers, it wouldn't interfere with the subwoofer at all. Anyone know a good single din HU with adjustable EQ with separate sub controls? Flipout would be preferred just for ease of use - Or cheap double dins so I can afford a conversion kit for my truck. I know double dins are much more advanced now, and If there was one that wouldn't break the bank I'd be interested.
799
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
518
Pkoblish
Pkoblish
California
Pkoblish
audiobaun
    May 19, 2024
    May 19, 2024
