Single 15, 12 or 2 10's?
EpicMango
I trust you guys. Gave me my first setup that rocked, so I'm back. Now here's the dilemma. For my next setup, I want to be at least JUST as loud and low and my OA15 in 3.1 cubes with a 1x16' port.
I can't exceed dimensions of 32x16x18, so my question is for my next setup should I do a single OA15 in 3-3.25 cubic feet after all displacment, a single OA12 in a perfect box, or 2 SA 10's in a perfect box? All setups will be on a ASPM-1500 wired at 2 ohms @ 600-800 watts RMS after gain.
Requirement is that the setup MUST be atleast as loud and get as low as my OA15 in my not so bad or good box. I can't downgrade, knowing I could've just kept my original setup..
Well, I just looked at prices for SA-10's and they are $185 apiece and thats way expensive. So instead of 2 SA-10's, i'd like pay around $250 tops for 2 quality 10's that abide by my above stipulations.
I already have 6 18's in a clamshell on my system for my computer at home. I don't like it very much, doesn't get low, and I've even tuned it to 20hz. -_- stupid OA18's >.
I'll be doing 2 ohms regardless, because My car can't handle more power, and I won't be needing to get past 140ish dB. 2 ohms for stability, efficiency, and SQ
Well with all the suggestions listed, I'm leaning toward a DC Audio level 2/3 15 in 3ish cubes after displacment. I'm leaning towards the Level 2 15, because I don't need to send much more power to the sub. Are those subs underrated because I want to send 600-800 watts to it. Hypothetically a DC Level 2 in 3 cubes vs OA15 in 3 cubes each at 700 wrms, which one would hit louder and get lower, cleaner? SQ=SPL
No point in buying a different sub if you are just going to push it with the same amount of power, and unless you have a honda with a 60 amp stock alternator, I'm almost positive you can run the APSM at 1 ohm with no issues.
80 amp alt. I want to switch subs because I can't put a OA15 in a good box around 3.4cubes, but I can do a 3 cubes box and it looks like a DC level 2/3 do fine in 3 cubes, or atleast better than a OA15 in 3 cubes..
All cubes are after sub and port displacment BTW
Plus, I don't NEED to get louder, if I kept my same setup i'd be just fine. I don't need 1300 watts of loudness, I'm just fine with 700 watts of dB. And apparently efficiency and SQ are better at a higher ohm load.
I'm perfectly content with what an ASPM-1500 for my situation does. This discussion isn't about my amp, its about a better sub setup!
the logical solution is to improve the box for the sub you have, unless you have clipped the sub to death or something. Why not do Aeroporting? You currently use only 16 sq inches of port?? Open that bitch up and hear what is going on with what you have before you throw good money at bad. 3.25 and 6" Aeroported.
EpicMango
EpicMango
Colorado
EpicMango
