Sinfoni Amplitude 50.4x High end amplifier
Thewavecaraudio
Sinfoni 50.4x
see other thread for Sinfoni Amplitude 150.2x and Shadow 50.2spx
Nice amplifier 10/10 working condition 10/10 cosmetic, was powering 2 xCDT ES-010 tweeters and 2 x CDT Es-04 mid , this amp is compact and put outs nice clean power, see the specs for detais
Specifications
Power Supply: 9 - 15 VccStand-by Current:
Input Sensitivity: 0,4 - 8 V
Input Impedance: 48 kOhm
Total Harmonic Distortion: 0,01 %
Frequency Response: +/- 1 dB 10 Hz-30 kHz
S./ Noise Ratio: > 90 dB
Weight: 4,9 Kg
Dimensions: 434 x 187 x 40 mm
Power Rating
4 ohm @ 12 V: 50 watt x 4
4 ohm @ 14,4 V: 70 watt x 4
2 ohm @ 14,4 V: 120 watt x 4
mono 4 ohm @ 14,4 V: 240 watt x 2
Equipment
Built in Cross-Over. Continuosly adjustable from 30 Hz to 250 Hz. Adaptable as low pass/high pass. 12 dB x octave mono/stereo.
850$ + shipping obo
Will be shipped with Canada post (USPS), tracking number, Paypal only
$850?//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
yes 850$ obo since you won't find any brand new under 1300$, but if you think there is a problem I guess you don't know these amps, that'ok you are not the right buyer anyway...
yes 850$ obo since you won't find any brand new under 1300$' date=' but if you think there is a problem I guess you don't know these amps, that'ok you are not the right buyer anyway...[/quote']
no need to get butt hurt... i was just commenting on how expensive they are, never said it wasnt worth it, i actually do know quite a bit about these amps. i understand how much they are new....
whatever,
glws.
Thewavecaraudio
Thewavecaraudio
Trois-Rivières
Thewavecaraudio
