Simple Yes/No Answer is all I need
JakeM
Sub Amp-Clarion DPX 1000.2
Putting 2 RE 12 (4ohm DVC) this is how im going to wire them
My amp is
250x2 into 4ohms
450x2 into 2ohms
1000x1 into 2ohms
So if I wire the subs like I showed you and bridged it to the amp I would get about 500 to both subs or 250 to each, right?
>>>>>>Is it okay to bridge it with 4 ohms?
Thanks You So Much!
Leaving Tomorrow for vacation and need some bass!
ok bro...each sub will be wired down to 2 ohms, then youll bring them together for a 1 ohm load but hmmm.....crap you can bridge them to a 4 ohm load but youd prolly be ok, or run a sub to each channel, also whats the power handling...???
450x2 @2ohms means 900 watts x1 @4ohms bridged
The subs will share 900 watts.
A bridged 4 ohm load is the same as a stereo 2ohm load except the signal is mono.
In short, yes it will work.
Just wire them exactly as illustrated in your sample.
the RE 12's are DVC 4 ohm with 175rms/250 max
If i wire it like above it will be 4 ohms, then I bridge it with the 4 ohms. is that allright for a amp?
i know going lower than recoomended like 1 ohm is very bad, i was wondering if going higher would be bad also
JakeM
JakeM
Houston
DJ Kontakt
BP1Fanatic
BP1Fanatic
