2000 GT.
ONLY 31,000 miles
Silver with Dark Charcoal leather, with pony seats.
Power everything except passenger seat.
It's got the Mach460 with an Alpine HU (CDA-9856) and the proper adapter so it still sounds clean.
Power everything except for passenger side seat.
EVERYTHING WORKS!
Mods:
Vortech V2SQ with aftercooler
battery in the trunk.
C&L intake plenum
Custom tune by Lamotta's Performance
Diablosport Mafia and Lightning MAF
42lb injectors
Focus pump
K&N in the fender
Line-loc
4:10 ring and pinion
31 spline axles with extended studs and FRPP traction-loc
Rear end girdle
MM tubular lower control arms
FRPP aluminum DS and loop.
Full Kenny Brown chassis stiffening, everything except strut tower braces.
Eibach Sportlines all the way around.
Brembo Cobra R brake kit on front.
17x9 Konig Villians with Falken tires with about 90% tread left
MM caster/camber plates.
Tokico Illumina 5 way adjustable shocks and struts.
Steeda Tri-Ax Shifter with Roush handle.
Steeda CLutch Quadrant and firewall adjuster
Zoom Kevlar clutch
MAC prochamber
FLowmaster 2 chamber catback. They need the tailpipes welded though. I used the clamps that came with them and the clamps broke before they tightened. I then got some stainless clamps, and they won't tighten enough. The tails are held in place fine, but you can move them with your hand if you want causing a slight leak at the muffler exit.
$11,500 I will also include a set of chrome 18x9 Saleen replicas with the car if buyer wants, but they need new tires and one center cap.
You can find a video of a walk around with the car running and a FULL compliment of photos at the following links.
GT pictures by tirefryr - Photobucket
2000 pictures by tirefryr - Photobucket
interior pictures by tirefryr - Photobucket Interior pics.
Reply here or tirefryr@att.net
No trades unless you have a nice vert and at least $6K
ONLY 31,000 miles
EVERYTHING WORKS!
Mods:
C&L intake plenum
42lb injectors
Focus pump
K&N in the fender
Line-loc
Rear end girdle
Zoom Kevlar clutch
MAC prochamber
