Signal lights blowing fuses
prolly too much current going through the fuse //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
thats an easy fix ...it would just need a bigger fuse ...you can always slowly increase fuse sizes 5 amps at a time till they quit blowing then the problem will be fixed //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Don't think that's safe.
Blowing fuse sounds like short to ground. Take out all the bulbs. Put each one back in one at a time and use the signals each time. What vehicle is this. Does it have a single fuse for all four. Or a fuse for each side. Most newer cars trucks have two, One for each side.
u checked all the wiring? maybe doesnt have ground.
If he didn't have ground how could it short? If you don't know, maybe you never will. Might want to leave your amp installs to the pros btw.
I'd think the relay is internally shorting. Get a multimeter and a 12v supply and test the relay (or buy a new one if you don't have tools to test.) 95% chance it's the relay, or wiring harnesses associated with the relay.
Mr. Slate
Mr. Slate
New Haven, Ct.
Mr. Slate
