twisztdauthorit
-db-
- Thread Starter
- #16
my calculations were off a little but it was pretty close to 39tuned to 40 right?
yes it would have been but if i let go of the paper it would of either got blown away or sucked in.... which happened a few min after i took the video... had a fun time getting it back out //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifwould have been more impressive if u didnt hold the paper in your hand and it rip instead of helping it rip by holding it in one spot.
The BXI2006D Powers the sub pretty **** well...nice vids, lets get some flex outside the car. and how does that amp power your que?
how much power comin from the amp@ ohms and rms?The BXI2006D Powers the sub pretty **** well...My port is to small compared to specs so I'm sure it would handle a lot differently with the right port..
The one i have right now is 2.5 wide 15 tall... 1/2 the recommended ..
anyways with my setup right now it seems as if it could take more power, no signs of physical stress on the sub.
the subs is dual 2 wired to 1 ohmhow much power comin from the amp@ ohms and rms?
Don't meant to try and make you feel bad, but you're getting less than that with impedance rise.the subs is dual 2 wired to 1 ohm
the amp is rated for 2000rms at 1ohm...
So I'm counting on around 1800 or more watts
=(Don't meant to try and make you feel bad, but you're getting less than that with impedance rise.
benched my 2006d at under 1500 watts. mines wired at 1 ohm. good electrical system.
and the vids of port air movement are just stupid. any sub over 100 dollars can do that.
The high amount of air movement is due to the small port, not so much from the sub. The sub is the driving factor but like said before, any cheap sub could do it. The sub is just driving the enclosure into resonance. The smaller the port, the higher the air velocity which is NOT a good thing. It may look cool, but it's really not a good thing at all.
