Shed Some Light Plz 4 An Idiot
RandyShaw
:confused:Geez i am adding a component system to my car. The system is 120 rms, and comes with a pair if woofer, a pair of tweeters, and crossovers. Since there are 4 speakers do i need a four channel amps? Or do i need something else b/c there are crossovers? I also have some 6x9's that are 100w rms that i want to hook up to the same amp. Can i do this? I am open to all suggetsions.
Thanks
a 2 channel amp for the components. Each channel goes to a crossover and then the crossover goes to the woofer/tweeter. If you want to also power the 6x9's then you would need a 4 channel amp. 2 channels for the component set and 2channels for the 6x9's.
Thanks alot, is there a big difference between active and passive? All i know is that it allows you to determine frequency before or after the amp. I was thinking passive because of the 6x9's, but i dont know much so fill me in.
The 6x9 are on the rear deck. I was thinking i would mount the tweeters like on the door or somewhere on the dash were wiring would be easy. The woorfers would go in the doors havent decided front or back.
RandyShaw
RandyShaw
Eau Claire, Mi
rollerdj
