Shark Audio??????
But you do????? And you asked what has happened to this forum. People like you that can't just give your opinion and move on. You just want to argue with everyone on here that post something that you don't agree with. You are what's happened to this (and many others) forum. Bash bash bash is all you want to do. I'm sure your setup out the bow was 5K+ with the best of everything. Move the fu(k on with you opinion and let your opinion be just that.
This is a great "starter" amp to get you going. Not something I would keep as my full time amp. I have one, and used it for a couple months till I got my AQ3500 (is that amp ok with you Tenacious???). Now it sits in a box as a "back up". It was wired to .5 on a 15" and worked real well for what it is. I'm sure it did real close to rated, but they do run hot regardless of what it's wired to. Take my experience with it for what it is.
The butthurt is strong
---------- Post added at 01:46 PM ---------- Previous post was at 01:46 PM ----------
just because you got nothing to say about the topic you start bashing the person, your like in kindergarten and a very sore loser
---------- Post added at 02:16 PM ---------- Previous post was at 02:16 PM ----------
and very close minded
Refer to my last post, applies to you too.
No offense tenacious but what is your issue with budget amps? You push so hard for people not to use them but I don't get why. You haven't presented any factual evidence against the shark amp except that you think they're similar to audio pipe and a friend blew a sub on an audio pipe. Doesn't seem like a strong argument.
I get if you're trying to steer someone away from making a possibly bad choice but youre at the point of insulting people and throwing around opinions as if they were facts.
I don't run anything that I'd consider budget but if people want to run it I have no problem. The only issue I have is when people tout their budget items as superior to higher quality ones. If people buy these budget items knowing their limitations then more power to them.
He's just the type of "brand dick rider" that has an opinion on everything whether he's used it or not. He has no experience on anything other than just talking out of his ***. Never owned, seen, or heard a Shark but because he's looked at some pictures he's now an expert. He'll soon become a troll of the forum that will only be useful in the Thunder Done section of this forum. You see he had no come back to my reply cause i'm right, he's useless here.........
Because dumb ***** like you spread that word that these garbage amps will suffice, when they won't, instead of spending the money for quality equipment.
Have you used this amp? Do you have any first hand experience with this amp? Do you know what it's capable of? I'm sure your answer to these are NO. So unless you have or can give some useful info on these with first hand experience, your opinion is just that.
These amps are the same as AudioPipe, various clamp tests and real world information shows that the AudioPipe APSM amps are ****, so yes, I do have a basis for my bashing of AudioPipe (shark in this case)
I don't put any brands on a "pedestal" so to speak so I don't see how I'm being a **** rider. This particular line has been proven to be a cheap POS.
Did you perform clamp tests along with oscilloscope readings to prove that these amps do clean power? If not then no one cares about your opinion either.
That's just it. YOU don't have any personal experience with it. They are not the same board, or amp. There has NOT been any bench testing of the Shark amp (that Ive been able to find online) other than my own from actually running one. Which is more than you can say. You may have read somewhere that they are the same but again you've never owned, ran, or seen one so you really have no clue. Giving out all this false info to people that you have idea is true cause you yourself have never done the testing.
Lmao OK buddy. I didn't mention any where that this was a great amp. If you were smart enough to comprehend the meaning of my post you would have seen the part where I mentioned that if you buy this amp, you should buy it knowing it has limitations. But I'm the dumb one...
I don't have to use the amp.
It's confirmed that it's another cookie cutter garbage board.
Just because it sounds good on your sub doesn't mean it's up there with the top companies.
Cookie cutter huh. Your just as ignorant as the other *******. Here....
AudioPipe APSM
Shark 2500
You fucking gay's need to stop being in denial.
You can't be this dumb. Are you actually reading my posts or just quoting me but responding to someone else. Please show me where I said run either brand. Actually don't. I don't want you to hurt yourself looking. I'll say it again. I DONT RUN EITHER BRAND
I'm not an idiot who blindly follows others opinions despite them thinking its fact. My only issue with this thread is the idiots bashing the amp because thy THINK its an audiopipe. Please show us all where its been "confirmed".
Look above your post buddy.
des343
des343
Kalamazoo, MI
Jeffdachef
Mike Mccabe
Giles
    Jun 27, 2026
