Sharing airspace
chrisgray
How will two subs sound sharing airspace in a sealed enclosure. Just curious it would make glassing the box sooooo much easier. It's gonna be two L7 eights. Also how would you figure the volume? Would you just combine space, doubling the space for one, or would there be more to it than that? I've always used separate chambers. They will be in phase/mono channel. Any help would be appreciated. Thanx Much //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
well well, it sounds the same, and yes, u only double the recomended vol.
but lets say 1 sub got diffectted or whatever, its not workin, other sub wont be playin nicely, it will actually be some how like playin it free air (its double the VOL.)
i dont recommend that. but hey wait for other comments //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's not necessarily true. It will definitely see the whole volume itself, which will lower it's mechanical power handling, but that doesn't mean it's free-air.
im woundering about two 12"s in a ported box... if its better in a single chamber w/ 1 port or 2 chambers w/ 2 ports
For simplicity sake, a single chamber is definitely the way to go IMO.
However, for a sealed box, another advantage of using a dual chamber box is that the dividing wall doubles as a nice brace //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif But as Jmac said, it's fine to use the same airspace
True, thats why i used "some how" //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
my bad, english is not my first language, thank god that i understand what u are sayin.
Well then, you are doing quite well //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif English is not an easy language to learn.
and hey, is it good to play a sub in double the rec. vol ??did u actually try that??
That's a really vague and hard to answer question. It all depends on the sub, your goal for the "sound" of the system, etc etc. Plus, the manufacturer's "recommended enclosure" isn't always the "best" enclosure, because generally manufacturer's recommended enclosures on the smaller side because it gives a nice peak in the lower midbass/upper bass region, which is what the typical street beaters likes his bass to sound like.
chrisgray
chrisgray
Childress, Tx
squeak9798
