Share another easy alternative tool to convert MKV to Apple TV, but Handbrake
I am trying to convert the latest Top Gear episode from a MKV file to an MP4 so I can put it on my Apple TV and watch it on my TV. I have every other episode this way. I used Handbrake to do the conversion job but it lost about 1/2 of the audio. MP4 file picture looks great, but the sound is as of every word is missing. Actually I played the MKV file perfectly with VLC player, but the converted MP4 file doesn’t. I guess something wrong in the conversion.
In order to hunt the right answer, I did some search jobs online. At the same time, I found some users have the same puzzles like me when they use Handbrake. Even worse, it seems that after about 30-40% conversion Handbrake just shuts down by itself when the user converting a 720 MKV (AC3) file to MP4 (Stereo). Is there another easy-to-use MKV converter instead of Handbrake?
Tried another ten similar MKV converter tools online from Google search, an all-in-one program called Moyea MKV Converter obtains my trust for its high fast conversion speed and perfect output quality with intuitive interface. What’s more, it can prevent any audio and video sync issue for its advanced audio and video sync technology.
If you just need this kind of tool to convert MKV to MP4 or other popular video or audio formats without any loss, the following tutorial will give you a favor.
After launching this all-in-one MKV converter and adding your MKV files into it, you can easily select output format from a drop-down format menu according to your device.
If you want to get better output quality, you can adjust audio and video parameters like resolution, bit rate, size, the aspect ratio, and codec, frame rate of Video and sample rate, channels, codec, bit rate of Audio. If your MKV files are 5.1 channels, this MKV converter can convert MKV files with 5.1 channels now.
Before converting your MKV files, you can also edit your MKV files with this MKV converter’s powerful editing functions, like cropping, trimming, merging, adding effects/watermarks and replacing audio, adjusting volume, etc.
As long as the whole MKV conversion is done, you can easily get the MP4 files and then put them on your Apple TV or other media players for enjoying.
That’s all. Hopefully the article will be of help for you!
