SethPhillips 99 Acura Integra V.2
Looks slick, running the wire to the front doors should be a lot easier since you have most of the panels removed. Took me 20 min each door on my 90 Teg, just drill a slightly bigger hole in the door clip and it should be a snap.
been there, done that..
the same 2 12 box as before?
nope new design. the old box was port and subs back. gunna keep it, if i dont like the sub up/ port back then i have my sub back/port back box to fall back onto, cause it was loud, and sounded great.
Custom made Volt Meter Pod.
14v with stock alt. kinetik 1400.
still have yet to install H/O Alt, Big 3, & Sec Batt.
that was my first thought once i powerd it up. and put it in the car. i was like **** that's bright! then i found out you can adjust the light output, and i dimmed it out a little bit. now its perfect!
Can you give me the specs for your new box? I am thinking of new box ideas for myself right now too. I may try and dip down into the spare tire well and try to get enough space to do an 18 but idk about that yet.
This kid is rocking a 18'' BL in his RSX. I have to imaging rsx/integras have pretty similar sized trunks so I am itchin to do a 18'' now. His sh1t looks violent......
Kevin
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
