Sold Selling my amps n battery for a new one.
dkc62
SoundStream®
I need a new amp for my juggernaut so I'm parting out my other ones.
Soundstream Rubicon 702 needs rca left input fixed but still plays mono.
Had a couple of buyers but I deleted the pms on accident.
Optima Yellow top. Had a buyer but I accidently deleted his pm so if you see this then get with me.
Atomic 800.1 amp. Bought this amp for a good deal but never ended up using it. A couple of scratches. I think it is a 1500 watt amp at 1 ohm. The manufacter date was in march 04.
MTX 5 channel amp thunder 405. Very great amp for a starter system and the sq is sweet.
If anyone has a MMATS ampthat would run my jugg at a lower independance than 1 ohm and you like something you see here that pm me.
Everything works perfectly except the Rubicon but it still plays.
Sorry for not having the prices.
Soundstream $100 shipped
Yellow Top D34/78 $110 shipped on the east coast
Atomic amp $240 shipped and it does have the 1500w board.
MTX $100 plus shipping
I really need a amp to push my juggernaut but all I have is trades here. I'm out of money till next week before I can even go amp shopping so post what you have if your interested.
**** I wish I could buy the other Atomic amp here then I would be set! //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
****it!
i was about to scoop that soundstream //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
specs on the MTX?
Well the soundstream is still for sale until this guy buys it from me. The MTX has a little less power than the mtx 895 but I would consider it just as powerful as the 895 because it's oldschool mtx.
review
I bought a used MTX Thunder 405 for my 97 GMC extended cab. I'd read that MTX made excellent amplifiers, but I had always been afraid to buy one because of the conservative power ratings. I found a deal on a used on on ebay so I took the plunge.
Specifications
MTX is notorious for under rating their amplifier output. They list the 12.5 volt average power for the amp as:
25 X 4 + 100 X 1 at 4 ohms
50 X 4 + 200 X 1 at 2 ohms
At 14.4 volts (approximate voltage of most automobile electrical systems) the power output increases to:
65 X 4 + 150 X 1 at 4 ohms
125 X 4 + 300 X 1 at 2 ohms
The factory test each amp before it is shipped and it must meet the minimum specs, MTX encloses a "birth sheet" with each amp so the end user will know how well their amp performed. The 12.5 volt results that were included with my amp are:
58 X 4 + 269 X 1 at 4 ohms
86 X 4 + 391 X 1 @ 2 ohms
It amazes me that MTX chooses to under rate the amp by that much! Obviously the marketing should state that the Thunder 405 is at least a 50 X 4 + 200 X 1. Why they chose to advertise the Thunder 405 at less than half it's actual output is beyond me, but it is one of the reasons that it took me so long to buy an MTX!
The Thunder 405 is capable of running with one, two, or three sets of RCA cables. There is an input select switch that is used to select your configuration. In order to maintain maximum control of your sound you need a head unit with 3 sets of RCA outputs.
The front and rear channels have variable crossovers that can be adjusted from 40 - 200hz withe the crossover select switch out or 1.8 - 9khz with the select switch pressed. For the sub channel, the crossover is adjustable from 40 - 200 hz (FYI - the newer MTX 5 channels don't have the variable adjustment). There is a "Bass EQ" knob that is nothing more than a bass boost, it gives you up to 18db of boost at 40 hz.
The Thunder 405 has an Electronic Bass Control port so that you can control the bass remotely using the optional EBC module. If you don't have an HU with 3 sets up preouts, the EBC can give you the dynamic sub adjustments that you need.
Installation
The Thunder 405 is meant to be the heart of your entire sound system, so as with any other 5 channel amp you will be running a lot of wires. MTX recommends 4 gauge power and ground wires and you'll need some heavy gauge speaker wire (I chose 12 ga). All of the connections at the amp require spade type connectors. I personally dislike making my connections this way. I prefer the type that have a hole that you insert the wire into and tighten.
The spade terminals are arranged sort of awkwardly, the front speaker connectors are staggered above the rear speaker connectors. It's not a big deal once the amp is installed, but you have to connect the rear channels before the front. The spade terminals also seem to be susceptible to breakage, they are make of plastic and flex excessively during installation, be careful not to apply too much pressure!
Expect to spend a while installing this amp. The mounting and connections will only take a few minutes, but running the wires is going to be time consuming. I installed my amp from start to finish in about 4 hours.
Sound
At first I was disappointed with the sound of the Thunder 405, as with any 5 channel (or other amp for that matter) you have to take some time to adjust everything. Once I got the gains set correctly I had to tinker with the crossovers and finally the Bass EQ. The end result is outstanding sound! The Thunder 405 has plenty of power, the sound is clean, even at high volumes. In the sound quality department the Thunder 405 can definitely hold it's own. It has more than enough power for me and can get louder than I want to hear!
Daily Use
The Thunder 405's heat sink is kind of smooth. I was sort of afraid that it might get hot in the limited space behind the rear seat of my truck. So far the amp just gets warm, even during extended periods of high volume.
Power consumption has not been an issue. The class D sub channel helps to keep the lights from dimming during heavy bass notes. The Thunder 405 has 3 25 amp fuses but I doubt it draws anywhere near 75 amps, my stock electrical system has no trouble keeping the amp happy.
Summary
The Thunder 405 a very good amp, it sounds wonderful, doesn't strain your electrical system, fits in a small place and is as reliable as they come. It's amazing that MTX is still able to produce such quality components in the USA and keep the cost reasonable. Since this amp is discontinued you'll probably only get a shot at one used, which means you can get a VERY good amp for a very good price!
Recommended
Yes
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
The Soundstream amp is sold, money is being sent tonight. Sorry Req, but I really want that amp. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dkc62
SoundStream®
dkc62
WPB FL and Eastern Shore VA
dkc62
