Sealing up doors
JeffM
I have my doors deadened with one layer on both the inner and outer door skin. Should I apply another layer? And what should I use to seal up that big hole in the middle of the door? The other two smaller holes cant be sealed due to wires passing through them.
*Note* this is not my picture. I have the same car as the one in the picture so I borrowed it to post here.
Anyone else use cardboard? its an interesting idea because it would be real easy to work with, but would it be strong enough?
Something tells me 'no.' I mean, I'd think it depends on what you put outside, how you attach it, and all of that. If you put deadener (one or two layers, preferably two) and caulk it on... I don't think they'll be much of a problem.
I haven't done it yet, but I think I'm gunna go with 1/4 MDF and caulk the sh!t out of it and put some deadener on it.
I might beef up the hinges for extra comfort //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
My doors are rock solid with the cardboard, its sandwiched in there to separate the front and rear waves and add durability and thats exactly what it does.
Nice, light weight, inexpensive and gets the job done. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/70539-diy-sound-deadening-most-important-part-system.html
i belive mdf or plexi is better due to the fact that they dont flex as much. i dont see how cardboard will help unless theres an insane amount of deadener.
1mdf sheet= cardboard+****load of dead
JeffM
JeffM
NL, Canada
bikinpunk
