sealed with the lows
i currently have a 12w3v3 in the back of my 06 330i in the zenclosures box (yes i know, prefab, but it does the job) but im looking to upgrade my sub and amp. i want to keep the same box because unfortunately I'm space over bass...
looking for a sub that'll dig lowwwwww sealed. thats all that matters; im basically wondering what sub will hit the lowest sealed. leaning more towards an SQ setup, but literally the only important thing to me is that it has a flat response especially in the LOW frequency range. i haven't heard anything but jlw3, and w6, so im basing everything on specs.
looking at the fi ssd (high qts) and ssa gcon. i do NOT want to spend more than $250ish on the driver. fi q seems to be everything im looking for with its 27mm of xmax, i just really want to keep my budget below $250.
also, got about 1.8ft^3 to work with, can only decrease it.
look at the c2 audio and see if the specs will work for you priced at $129 each DVC 3inch voice coil dual 160oz magnet its very beefy. for sealed you will need to put a lot of power on it unlike ported and these with 3 inch voice coil will take a lot of power even though its only rated at 600w heres the specs
Threatcon Sub 12" 600watt $129
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Do you need 1 or two subs?
For cheap two kicker comp 10s will sound good
Two jlw6 10s would sound alot better but pricey
Two idq 10s would sound great
An incriminator audio flatlyne 12 would be a good choice
The jl w6 13.5 works good
Idq or idmax 12 will sound good
2 fi q or ssd 10s or 1 12
Ssa icon or xcon 2 10s or 1 12
Older re audio subs did good sealed
The ultimate seal sub for me was a Mach 5 IXL 12 but they were made in Canada for just a short time and are hard to find
Personally I would go with two 10s or 8 sundown sd2 8s
W7 or the XXX does very well sealed and the low end impact is killer. If you want real impact sealed its going to cost you, you need power and not many subs that take power work well sealed. Look for high excursion and good power handling
Just outta curiosity do you agree with what I posted?
drakeisola
drakeisola
United States
winkychevelle
