SD12kD - teaser pics and info
With the testing I've had so far with the SD1800... I'd believe it.
They are quite the powerful amps. I'd have more numbers up, but apparently for reason unrelated... one of my batteries went bad and might have taken the other two with them...
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
nG
Joking aside, they do look interesting.
Dennis is dumping his two Autotek MM4000 units for the top line one.
We'll see what this 3kw unit can do. And yes, they will run fine in normal setups, but are built to "dump it all out" regardless of distortion ratings for SPL comps.
Folks,
the amps are designed for daily abuse, and any good designed daily amp can do fine in competition. The freq response is 10Hz to 15kHz and DF is 200 at 1 ohm or 800@4ohms.
murilo
murilo
Winnipeg
aphinney
