Half Way There I Have 17 Left
The Sundown Audio SD-1 10" subwoofer was made in the USA to some of the most exacting standards in the industry. The SD-1 is capable of producing great sounding bass in lower powered applications without breaking the bank. This woofer was designed with incredibly small enclosures and shallow mounting areas in mind.
FEATURES AND SPECIFICATIONS:
Non-conductive Kapton voice coil former for reduced eddy-currents and improved sound quality
Chamfered pole vent for increased cooling
Rigid polypropylene cone for long life in the harsh car environment
Rear mounting gasket for an air tight seal
Strong stamped steel basket
Extremely shallow mounting depth of only 5 inches
Single 8 ohm coil to easily match any Sundown Audio Amplifier; a pair works great with the SAX-100.2 and as many as eight can be ran from an SAZ-1500D with excellent results!
$110 US Dollars - MSRP
$137 Canadian Dollars - MSRP
T/S Parameters:
RMS: 200 watts
Peak: 350 watts
Z: 8 ohms
Re: 6.93 ohms
Fs: 25 Hz
Qms: 8.8
Qes: 0.36
Qts: 0.34
VAS: 67 L
BL: 17.5 NA
Enclosure Recommendations:
0.5 ft^3 - 0.75 ft^3 sealed
1.00 - 1.25 ft^3 tuned to 30 – 35 Hz ported
Click to enlarge
T/S Parameters:
RMS: 200 watts
Peak: 350 watts
Z: 8 ohms
Re: 6.93 ohms
Fs: 25 Hz
Qms: 8.8
Qes: 0.36
Qts: 0.34
VAS: 67 L
BL: 17.5 NA
Click to enlarge
