Sold Scooters Replacing it all thread: InDash Monitor, Subs & Amps
scooter2479
All my stuff is in 100% working order. Will only accept USPS Mone orders only because I don't want to pay the paygay fees any more. Any questions, feel free to ask. Everything is described 100% accurate. I have heatware and I've bought and sold here, anantech forums, hard forums, ebay etc... Here we go:
JBL BP 1200.1 Amp. This will do 1200 watts plus at 1 ohm. Awesome amp. It's a little dirty and a little Scratched up but 100% functional. I will clean it up as much as I can before it goes out. : Again, Some specs:
For more than 50 years, JBLs mission has been to develop and refine audio products that satisfy the most demanding enthusiast. In the studio, in concert, at the movies, or on tour, JBL is everywhere sound matters. JBL PowerValve series amplifiers deliver pure, clean power with the soul of JBL pro gear. The PowerValve P-1200.1 features a high-efficiency Switching power supply that draws far less current from your vehicles electrical system. PowerValve amplifiers are also 2-ohm optimized, and can run a 1-ohm load with ease. The "Direct Connect" terminal block power connectors allow for either 8 gauge or 4 gauge power wire, and the die-cast aluminum heat sink uses the entire amp footprint for efficient cooling. Plus, the buttoned black chassis with embossed JBL logo has an awesome, menacing look. With selectable 2- or 4-channel inputs, PowerValve amplifiers can be hooked-up for non-fading bass. Drive your subwoofers with JBL PowerValve power and you'll know why JBL is the official brand of live music.
Product MPN
MPN BP1200.1
Key Features
Amplifier Type Mono Channel
Bridgable Not Bridgable
RMS Power at 4 Ohms 600 W x 1
RMS Power at 2 Ohms 1200 W x 1
Performance
Frequency Response 10 Hz - 320 Hz
Signal to Noise Ratio 90 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 50 Hz
Low - Pass Frequency 32 Hz - 320 Hz
Other Features
3 Way Ready No
Dimensions
Width 14.81 in.
Depth 2.69 in.
Height 10.81 in.
Asking $200 Shipped O.B.O
Next:
Alpine IVA-C801 MultiMedia Center. Comes with the deck, brain, all installation wires to get it up and running. The only thing it won't come with is the front trim ring and the metal sleeve.
The screen itself is in mint condition. The brain cosmetically looks ok but functions 100%. I bought this on e-bay and the previous owner said it worked but it didn't so I sent it to alpine to get it repaired. They went thru everything and fixed anything that was wrong with it and put it thru a 3 hour bench test, so There is nothing wrong with it. I switched cars and now in a neon and there are limited places to mount the brain so I'm going to go after something else.
Here are some specs on it:
This Mobile Multimedia Station gives you the ultimate in system personalization. From mild to wild, you can build a system to incorporate any source from video games, DVD, VCR or Navigation! It even has a built-in CD player. You will have full flexibility to use built-in power or custom build to multiple amplifiers and speakers. Remember, with Alpine, you get what you want without settling for second choices!
45W x 4 MOSFET Amplifier
6.5" Fully Motorized Monitor
Bass Engine
"Digital Art" Spectrum Analyzer Display
Built-in CD Player
MaxTune SQ Tuner
Ai-NET Control Center
2 Auxiliary A/V Inputs
Dedicated Navigation Input
Auxiliary Monitor Control Output
Dual-In Circuit
Rotary Encoder Volume Knob
Navigation Audio Mix
Subwoofer Level Control
4 Volt PreOut
3 PreOuts
You can hook up a dvd player, navigation,
PS3, Xbox360 and more to this unit. It has a built in cd player.
Looking for $325 shipped. Great system! USPS money orders only
http://i127.photobucket.com/albums/p...10-07_2228.jpg
http://i127.photobucket.com/albums/p...10-07_2207.jpg
Next:
Kicker CVR122 - CompVR 12" Subwoofer 2ohm DVC
12" sub with dual 2-ohm voice coils
Ported box volume: 1.75-2.25 cu. ft.
Power handling: 50-400 watts RMS
Peak power: 800 watts
Sensitivity: 86.5 dB
Double-stitched, foam-ribbed Santoprene rubber surround
Frequency response: 25-500 Hz
Top-mount depth: 6-5/16"
Sealed box volume: 1.0-4.6 cu. ft.
Injection-molded polymineral cone
Mint condition. Only used a couple a months. 75.00 +shipping o.b.o
Next:
12" "Punch HE" Subwoofer
Single Voice Coil
Power Handling: 200W (RMS) 400W (max)
Nominal Impedance: 4 ohms
Sensitivity: 87.6dB
Frequency Response: 28-200 Hz
Voice Coil Diameter: 2.5" (4-Layer)
Mounting Depth: 5-3/4"
FIBERLock Woofer with Large Roll Treated Foam Surround
Concealer Gasket
Still in great condition. This sub pounds! 60 + shipping
o.b.o
Last but not least:
Kicker ZR240 Amplifier -
Rated Power 4-Ohm Stereo: 2 x 60 - Rated Power 2-Ohm Stereo: 2 x 120 - Rated Power 1-Ohm Stereo: 2 x 150 - Rated Power 4-Ohm Bridged Mono: 240 - Rated Power 2.66-Ohm Bridged Mono: 300 - Rated Power 2-Ohm Bridged Mono: 300 - Frequency Response: 10Hz - 28KHz; +0, -1dB - Signal to Noise Ratio: > 100dB, unweighted, re: rated power - Input Impeadance: 22k Ohm - Input Sensitivity: 150mV - 3V RMS -
- 8 gauge power/ground inputs - 10 gauge speaker inputs
Doesn't have the kicker plate on it but thats how I got it. Little dirty in the pic but 100% working. This sub is known to be underrated! I will clean both amps before they get shipped. Askiing $150 + shipping o.b.o
As I said before, everthing is 100% working. Everything is o.b.o just don't lowball cause I probably won't respond. I'm open to trades, just let me know what you want and what you have and we will talk. Thanks!!
scooter2479
scooter2479
Macon,Mo
scooter2479
