Schematics for 15'' Top Firing, Rear Ported Enclosure
I've decided that I want to go top firing, rear-ported, 4.0 cubes @ 32hz. Max dimensions are 40"x30"x40". I didn't like the way subwoofertools was designing the port, so if anyone can help, it would be much appreciated.
Sorry for being unclear, but I want sub up, port back. The box is being installed in the back of my '03 Trailblazer. I went out and took exact measurements, and my max dimensions are 45''x37''x20.75'' (width x depth x height). If its at all possible, try to keep the height right at or around 20.75" so that the top of the box is flush with the top of my rear seats. I really appreciate all the help, let me know if you need to know anything else.
Im doing it now.
Also, in the SUV's (some) of my friends, port and sub back was louder than sub up, port back. But it is a different design then the plain port back, sub back so it's really up to you.
Ill do the sub up, port back, but I can switch it easy if you want.
Yea man, that sounds perfect to me. I really appreciate the help. If you can get the sketch up that would be great, but if not, don't worry about it.
I was messing around with skechup and I got:
If anyone could double check those dimensions, I would greatly appreciate it.
I have no clue what dimensions the green/red/blue parts should be. I knew you said the port is 3.5" wide with 63 in^3, but I did some searching and only found a thread that further confused me.
I'm planning to use a double baffle, so would I just add another layer of MDF to the top? If so this would give me:
Can anyone check those dimensions?
Rzaa
Rzaa
wv
Rzaa
