This enclosure is being designed for a Adire Audio Brahma 15dr4 MkIV being powered by a Hifonics 1606d amp. I mostly listen to rap/hip hop, but theres a little bit of everything on my ipod. I'm planning to install it in the back of my '03 Tralblazer, so space isn't much of an issue.
The only thing I've decided on so far is that I want it to be top-firing and rear ported; other than that I'm pretty much in the dark as far as design goes. Right now I'm leaning towards somewhere around 30-35hz @ 3-4 cubic feet.
Here are the specs on the driver:
Fs 24hz
Qes 0.59
Qms 8.2
Qts .056
Vas 152 liters
Re 2 x 3.3 Ohms
Le 2 x 0.34 mH
BL 19.0 N/A
Xmax 28.5mm
Sd 740 cm^2
SPL 87.4 dB
Pmax 600W
If anyone can help me design/knows of a schematic that will suit my needs I will much appreciate a point in the right direction. Any help at all is appreciated, thanks beforehand.
Fs 24hz
Qes 0.59
Qms 8.2
Qts .056
Vas 152 liters
Re 2 x 3.3 Ohms
Le 2 x 0.34 mH
BL 19.0 N/A
Xmax 28.5mm
Sd 740 cm^2
SPL 87.4 dB
Pmax 600W
