SCAM? Branden
Qbenjamin
branden
Registered Member
Posted - 04/14/2007 : 15:35:51
I just purchased an HCCA-D2400 and when i try to turn it on, the red light and the ESP Indicator lights just blink.... the amp will not turn on. I bought it used, any idea how to correct this issue? Thank you very much
Derek Dawson
Moderator
Posted - 04/17/2007 : 00:00:32
You're only sort of reset is just unhooking power to the amp. Although, if the fault wasn't there the amp would automatically reset itself. Verify all your connections, unhook the power, and if it doesn't work at that point it would sound like something is wrong internally with the amplifier.
branden
Registered Member
Posted - 04/18/2007 : 08:22:58
ok, the reason the ESP light was blinking was because of low RCA voltage, i corrected the problem however I need to reset the amp so it will turn back on, its stuck thinking its getting low voltage even though the problem has been corrected.
i tried unhooking every wire...the power, ground, and remote but it still will not reset. Help pleeeeease!
Derek Dawson
Moderator
Posted - 04/19/2007 : 12:17:57
I'm pretty sure you emailed and called so I'm just going to leave this one alone at this point
Posted by branden on 4/26/2007 : 10:08:05
Orion HCCA-D2400 $250 shipped
Amp is in pretty much perfect condition beside miniscule scratches. $250 shipped. The amp puts out...
400watts RMS @ 4 ohm
800 watts RMS @ 2 ohm
1,200 watts RMS @ 1 ohm
Watch out for this scam, he claims there is nothing wrong with the amp on here but makes posts on OrionCarAudio.com and SSA forums. BEWARE!!!
Qbenjamin
Qbenjamin
Braavos
CaliforniabOY5
