saz1500d v1 actual output at 4, 2, 1 ohm?
Rated power output
----RMS power, 2 ohm linkable/dual mono 3000W x 1CH
----RMS power, 1 ohm mono 1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono 400W x 1CH
if you do a search on this forum there is a guide on how to measure your actual rms of your amp
actual increase in benched power is irrelevant in this case when you factor in impedance rise and some voltage drop so expect the published rated power
****, first time I heard that. Good point.
also som1 elses amp wont have the same output as your amp even if they are the exact same.
True, but it will be pretty close won't it?
Momax and side show are 100% right. Every test will vary if its vehicle/power supply or woofer/resistive load and box rise changes.. But here's a test of the three impedances you've asked for anyways
4 ohms 1% THD 611 watts RMS
2 ohms 1% THD 1048 watts RMS
1 ohms 1% THD 1656 watts RMS
2010HHRUMADBRUH
Gold Diamond Plus VIP+ Member
2010HHRUMADBRUH
East Bay, CA
akadj
