Saz 3000d
TeZ
Sundown 3KD
9/10 Cosmetically, Has a few scratches on the feet from mounting
10/10 Mechanically,
Ran at 13.5 to a RE XXX
SPECS:
* Double Sided Through Hole Epoxy PCB
* Efficiency : 86% @ 4 ohm, at 100Hz
* 24dB/Oct Variable Crossover
* Multi-Way Protection Circuitry
* (Thermal/Over Current/Speaker Short/Speaker DC Protection)
* Variable Subsonic Filter
* Variable Bass Boost
* Variable Low Pass Filter
* Variable Phase Shift
* Zero(0) Gauge Power Supply Connectors
* Tested Voltage & THD : 14.4V & Less than 1% THD
* Operating Voltage : DC 10V~18V
* Digital Class-D Linkable Mono Block Amplifier
* 1 Ohm Stability
* RCA Line Input and Master Output
* 24dB Octave Crossover Slope
* Wired Remote Controller
* MSRP $1549 USD
----RMS power, 2 ohm linkable/dual mono
6000W x 1CH
----RMS power, 1 ohm mono
3000W x 1CH
----RMS power, 2 ohm mono 1600W x 1CH
----RMS power, 4 ohm mono
800W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 53(H) x 594(L)mm
550 Shipped in Continental US
Price includes shipping
TeZ
TeZ
Delavan, WI
TeZ
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
