quoted before edit. Damn, you like them saggy assesI guess...... I think if rather have a saggy a$$ tho......
Think I'm gunna try these.... Did they work good for you?autozone coil spring spacers bout 15 bucks i had some on my car cuz i was draggin *** it wont rly raise u too much, but it def helps u from saggin
http://images.oreillyauto.com/parts/img/large/spr/18-1201.jpg
I've installed a couple sets and made a set, they should get you back to a normal ride height unless you have literally no suspension left in that case they will do nothing.Think I'm gunna try these.... Did they work good for you?
You mus be out yo gawd dan mine!has anyone suggested taking all the audios out? Cheapest option there is. And if you sell the audios, it's the option that makes you money
You can add to your leafsprings,just be careful, and use a jack and maybe a c-clamp for the existing.I lowered mine w shackles from Jegs to level off my truck..was under $100 shipped,but if yo want to raise it,add to leaf springs is cheap, or taller shackles( i think thats what they are called?)Been a couple yrsso no springs? or do they go inside the strut and take the place of the one in the strut? Im asking because my mountaineer is starting to sag and I need to add a few more subs and a bigger box.
