S10 False floor , Box Mounting
You do not have to really mount your false floor as it should not move around if made correctly.
If the floor is not even due to a hump or so then add 2x4's on each end to make the floor even.
As far as mounting the sub box you can do it in many ways. "L" shaped mount bracket, Glue, Bolts, Screws
Thanks , the *false floor * seems to be nice and level now ,and seems it would be fine . I 'll have a xs battery and the subs/enclosure , and amps all on top so i was thinking it would be good but thought i might check to be sure .
Timewarp
Timewarp
Brevard,Fl
Timewarp
