Running wires???
taysextreme
Want some Come get some
Im running 0 ga wire to the rear to a dis along the driverside and while i hade everything open and clear i was going to run the remote, rca's, and speaker there as well. would that be a good idea?
and also is there any one using 4 channel rca's to supply signal for two seperate amps?
All a four channel rca is is 4 channels.
All a two channel rca is is 2 channels.
If you can make a 4 channel rca reach both amps, then its ok to do that and you would save money over a two two channel rca's.
However, because you might change your system in the future, it might be advisable to do two separate ones so that you can have more mounting options with different amps.
taysextreme
taysextreme
jersey
taysextreme
vegang
vegang
