running two amps
You can test the output with a DMM if you want and set the gain exactly the same and everything else. Check out the gain sticky in the amp forum.
Another thing your going to want to think about is if you can keep all 4 channels in one signal (I'm talking about mono). I may be wrong, but playing one vc in right and the other in left (or in your case 2 vc's in right and the others in left) is not good for the subwoofer. I don't know much about audiobahn amps so good luck with that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
You can find a digital multi meter for a dozen bucks or so at walmart, autozone, home depote, you get the idea. You could even get an analoge one, but I'd stick with the ones with digital readouts, much easier.
damanTO81
damanTO81
marrero, louisiana
damanTO81
