Anonymous
I have heard so many different things from different people regarding this issue. Some people say that you need a relay or isolator because the batteries will drain from each other and other people say that you don't need to run a relay or isolator just run all the batts in parallel. Which method is correct? My front batt is a regular batt and 3 back are 3 Deka deep cycles. Reason I ask is because I had a 250A Mechman alt that just shit on me an I was not running any power, the only thing that was hooked to the alt was the batts.
