Running a XX-Colossus II, semi-stock electrical?
If I were in your position I would drop it in and I would do the big 3 with 1/0 awg wire. What battery do you plan on using as a second. Also, what speakers do you plan on using with the amp? It will put some strain on your electrical, but after installing it, work on getting a bigger alt.
:edit:
The alt is out of the question, I don't have the cash
edit: I think I need to find a amp that does 2000wrms @ 2ohm to avoid upgrading to a bigger alt, any suggestions? I was looking at a Viper D2500
Get the XX-Colossus, if it's drawing too much current, turn ur gain down. Set it so it runs around 2000watts and it wont be drawing as much current. W/ the 2nd battery and big 3 u should be okay if u watch ur gains.
gc86
gc86
South San Francisco, CA
phyphoestilic
