Running 1/0 wire from emgine compartment
I need some ideas on how to run 1/0 power wire from the engine compartment into the cab area.
I have a 2012 crew cab Chevrolet Silverado.
either through the main firewall grommet by the steering column on the drivers side or if you plan on adding multiple runs go under the frame and through the back wall where the vents are - youll have to look behind the seat most likely. pretty sure 99-07 silverados have similar designs to the newer models besides some obvious changes
prodjay
prodjay
Bossier city, la
kcr357
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
