Routing nitrous feed line quetion.
I dont understand the question....do you mean can you route the nitrous line from under your hood threw your firewall to the inside?
It wouldnt be safe being as you could have a leak on the inside and that wouldnt turn out to good
Yes you can run it that way. Only issue "might" be racing at a track as it might not pass tech, so if that's your plan find out what the rules are first...
YES,I not only run my line in the car but also the bottle.........
Heres my 15lb bottle , I keep it inbetween the 2 seats
Legal (w blow down tube)and easier for my races
Thanks man.
We just finished up last night installing a 75 dry shot of Nos on a Mustang GT 1998. Also if you can help me out. What kind of spark plugs should I go with and how much should I retard timing?
its def fine to run it thru the inside if the car. You will NOT pass tech @ some tracks, but you'll be fine if you're just going to a regular test and tune night. you should definately retard the timing 3-4 degrees, but change the plugs 2 heat ranges cooler than stock, and gap them real close so you get a good burn w/ them. The better the spark the better the fuel will burn, and more power w/ nos. I dont know if you have one, but get a purge kit, b/c they make a HUGE difference on smaller shots like that.
I want to put Nitrous on my Buick...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
do it.....lol
I actually put a 200hp shot on an old 87 ford escort........it hauled ass, and had crazy torque steer for about 10 minutes.......until I shot a rod thru the block:D
good times:D
sentra95
sentra95
AZ
Ignatowski
