Router bits?
jakel
I just want to know what router bits are used to make sub rings and to have that nice round edge on it. and the gap to stape the fleece to the box/ring..if you dont mind some pics of what you all use.....
i have a router table and router but dont know to much about the bits.//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif what are the most used ones and a breif discription of what they do would help..
thanks for your help.....
sprial up cut for cut outs
3/8" 3/4" round overs for edges
Flush cut for flushing edges (real nice and makes for a clean job)
rabbit bit (im pretty sure thats what its called) for cutting the edge for carpet, but this can be accomplished by spacing the sides in 1/4"
and buy quality bits
not to thread jack //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
but is the flush bit what you would use to flush mount drivers?
and ive been using the straight bit that came with my router and it works fine. I forgot the size though.
not to thread jack //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifbut is the flush bit what you would use to flush mount drivers?
nope, we used the spriral up cut to flush subs. Just nibble a little out at a time
the flush cut bit, cuts edges flush. Its a Basically straight bit that have a bearing on the bottom. It rights along the bearing flushing the edges down. Its good if some pieces are maybe like 1/16th 1/8" too long and over hang. It will nip that lil hang over off.
The flush-cut bit is used to cut one piece flush with another. Say you had a joint in your box that didn't line up exactly and one panel was a little bit too long. The flush-cut bit would cut the extra length off using the other piece as a guide. It's basically a straight-cut bit with a guide bearing the exact diameter as the cutter on the end of it.
Typically if you want to flush mount a driver, you make a double baffle. The driver is mounted to the rear piece and the cutout in the front piece is the overall size of the driver.
Never found a use for a 3/4" round over. Too big to be practical. I have a 1/2" 3/8" and 3/16" that I use regularly. I need to get a 1/4".
No you dont. Look at the post above you. you both ****. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
my desribtion is better //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
jakel
jakel
san antonio, tx
jakel
