rounding edges w/o router
random orbit sander.. good way to round off every sharp edge on a box in 10 seconds flat //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Just grab a 2" wide wood rasp, it'll shave the corners faster than a sander, and then a bit of elbow grease with some 60grit and you'll be fine. Exactly how I just did mine yesterday, and it turned out perfect.
Just rent a router. ie: buy one then return it when you are done.
I have never done this myself nor do I condone it but a friend of mine says he see's it happen all the time where he works.
i dont got a router but i have other powertools at my disposal such as drills, table grinders hand held grinders etc...is there any type of bit or wheel attachment i can get to round off all the edges of my box?
if i am lazy about changing the router bit i just use a sander with 40 grit sand paper
Well, its fast lol.... Maybe not as fast as a router.
After some 60 grit (following the rasp) you won't tell a difference from a router once painted. I did mine yesterday (and I have a router too, didn't feel like taking it out lol), and it turned out fine.
Just a cheap alternative
I wish i had about 6 routers so i didnt have to change the bits and all that. gets annoying as ****. but they are a life saver.
Thats the reason I didnt use mine lol. I got a nice carbon bit set for x-mas too (30 some bits) and haven't even used any lol. I just needed a corner rounded, and it was either take out the rasp and do it. Or pull and extension cord out, take the router case outta the cabinet, plug that all in, get bits out and put in, get glasses... just seemed like a PITA because I was in a hurry, and didn't want a mess
understandable. if it was the whole box i would say you are an idiot for not using a router. but it wasnt so your not.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well I wanna prime and sand it down very smooth so I can paint it.
Router is a good investment. Just go to your local pawn shop and pick up a used one, and a $50 variety bit set from ebay.
If your painting your box duraglass is your friend, use it to fill in the seems and sand it down. I recomend using a catylized primer and an automotive paint.
titanle
titanle
BC, Canada
kovemaster559
