round port to slot port conversion
I am trying to design a ported box for my subs but I'm having some trouble. The manufacturer requires a 4" x 14" round port. When converting from round to slot port, do I only need to worry about surface areas of the port? So each 4"w port would have 12.57^3 in of surface area, so I would need 25.14^3 of port area for 2 woofers in 1 chamber? Then the length would determine the tuning freq?
The box's net size determines the port, you need a certain port area for the given box dimensions, you figure it like this
Net box x 16 = port area necessary for max output (or close to it). This is the formula Digital Designs uses and it works very well for most applications. I never really had great luck going by the manufacturers recommendations, they tend to leave a little on the table most of the time...
So basically for a 2.0 ^3 chamber after displacements of woofer and port, you need about 32 SQ" of port opening to be in the upper efficiency range of that particular box.
The location of the ports is pretty car specific. In a trunk car (which I think yours is) unless you wall off the trunk behind the seat completely usually the best placement is sub forward port back, but sometimes sub forward port forward will work better, you kind of need to play around with your particular car unless someone here has done that specific car....
THATpurpleKUSH
Fuckyou
THATpurpleKUSH
Slums of the Shaolin
91caprice
