round port help
the general rule is 9-13 square inches per cubic foot for round ports. you are around 2.2 sq in for the .8cft box. go with a larger diameter to keep port noise at bay.
For a tune of about 41Hz I'll have to run a longer port with a 3" port diameter
For a tune of about 36Hz I can run the smaller/shorter port
The main reason i was going with the 1 1/2" port is b/c I can run it out the top of the box unrestricted if I run the 3" I'll have to run out the front of the box which will be about an inch from the back of the seat. If someone could double check my figures for ports that would be great. I want this to hit LOW and LOUD
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
bad03ranger
