KurtisMac
Hey all,
Complete rookie here but I would like to set up a decent audio system. I am not looking for a head pounding set up requiring to much juice, i would just like to hear crystal clear music, sounding like the way they should..high base if it is required etc...
The vehicle is an LR3 pretty much with a base audio..Which cannot be removed so to enhance my musical experience I have identified the following components:
Rockford Fosgate 3SIXTY.2
interactive signal processor lets you expand and fine-tune any car audio system
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=1&series_id=49&family_id=50&item_id=106187&locale=en_US&p_status=
2 sets of Polk Audio MMC6500 6-1/2" Component System (Front and rear door speakers)
frequency response: 43-25,000 Hz
power range: 10-125 watts RMS
peak power handling: 250 watts
sensitivity: 90 d
Eclipse XA4000 125W x 4 Car Amp
4-channel car amplifier
125 watts RMS x 4 at 4 ohms (175 watts RMS x 4 at 2 ohms)
350 watts RMS x 2 bridged output at 4 ohms
ICEpower® full-range Class-D amplifier design
INFINITY-BASSLINK-T
10" subwoofer and 2 x 10" passive radiators with built-in 250W RMS class D amp
I’m concerned about space and ******* the life out of the battery which is pretty much used to power everything (from suspension to just about God knows what). Plus I’ve opted for a powered woofer set up to avoid throwing in an additional amp, and getting a bass box designed..and to save space. I would appreciate any help and advice anyone can give….
Thanks
sensitivity: 90 d
INFINITY-BASSLINK-T
Thanks
