roof bracing???
  • 5
RangerDangerV2
st cloud MN
I recently pulled out all of the ranger's carpet and I am getting ready to start bracing and deadning.... now for the roof I was going to brace it with a sheet of mdf... the question is should I put up the mdf first and then deaden over the mdf bracing or vice versa???
you may want to make MDF ribs that are siliconed to the roof. then the new MDF sheet can attach to the ribs and you can deaden the metal in-between the ribs. that's what i've seen done.
no reason to deaden MDF, and once you cover the roof you won't have access to deaden metal.
you really don't need deadening anyway - you just want rigidity.
Don't use MDF as it will delaminate if the roof still flexes. I used birch in mine, still had some flex and you could hear the outer laminate tear apart.
I prefer a solid hardwood, even 1" pine is fine. Use PL glue to attach it.
idk what you have for a vehicle but in my tiny ass chevy prizm the roof took 13 cans of sprayfoam cause there was a 2” gap in the center i have...
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
RangerDangerV2
RangerDangerV2
st cloud MN
mlstrass
    May 19, 2024
    May 19, 2024
