Sold ROCKFORD T600-4 amp FS $150
lucas569
ct
selling this hella cheap! $150 + shipping. bad news is it needs repair. not a big deal really but thats why im selling so low.If i repair im keeping it! Its that frickin sweet and its mint too! This amp is way underrated check out the review of its little brother the T600-2, you can see this RF series easily is 20-30% underrated http://www.caraudiomag.com/testreports/caep_0709_rockford_fosgate_power_t600_2/index.html
i hit a huge pothole in my home town and the Pos+ wire accidentally came loose now it has some static noise coming thru the channels. even after repair your getting a hell of a deal, ill post up pics soon.
specs/details here http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=104&family_id=107&item_id=107997&locale=en_US&p_status=
Number of Channels 4
Rated Power
continuous power 100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
Total Power
total sum of 'rated power' 600 Watts
Dynamic Power
powercube measurement (info) Front Channels
139 Watts x 2 @ 4-Ohms 0° Res
236 Watts x 2 @ 2-Ohms 0° Res
Rear Channels
140 Watts x 2 @ 4-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 70% @ 4-Ohm
64% @ 2-Ohm
Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output Low Level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch EQ
(overrides rear channel built-in Punch EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1dB
Shipping Weight 12.00 Lbs.
(5.44 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
lucas569
lucas569
ct
lucas569
