Sold ROCKFORD T600-4 amp FS $150
lucas569
ct
selling this hella cheap! $150 + shipping. bad news is it needs repair. not a big deal really but thats why im selling so low.If i repair im keeping it! Its that frickin sweet and its mint too! This amp is way underrated check out the review of its little brother the T600-2, you can see this RF series easily is 20-30% underrated http://www.caraudiomag.com/testreports/caep_0709_rockford_fosgate_power_t600_2/index.html
i hit a huge pothole in my home town and the Pos+ wire accidentally came loose now it has some static noise coming thru the channels. even after repair your getting a hell of a deal, ill post up pics soon.
specs/details here http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=104&family_id=107&item_id=107997&locale=en_US&p_status=
Number of Channels 4
Rated Power
continuous power 100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
Total Power
total sum of 'rated power' 600 Watts
Dynamic Power
powercube measurement (info) Front Channels
139 Watts x 2 @ 4-Ohms 0° Res
236 Watts x 2 @ 2-Ohms 0° Res
Rear Channels
140 Watts x 2 @ 4-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 70% @ 4-Ohm
64% @ 2-Ohm
Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output Low Level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch EQ
(overrides rear channel built-in Punch EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1dB
Shipping Weight 12.00 Lbs.
(5.44 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
actually i did, i got one from RF at $100-$135 a repair request from the amp God himself (this is the guy i actually may send it to if keep "ZED") as hes going to upgrade an already awesome amp
Dear Lucas,
Yes we do repairs on all makes of amplifiers.
Please include a daytime phone number so we may contact you with the cost of the repair.
Zed does not charge an hourly rate but rather what the repair is worth.
We also offer an upgrade service which includes a capacitor, IC chipset and power transistor upgrade. The cost of course depends on the level of change required and the particular type of amplifier.
Zed does NOT charge for estimates.
Payment may be made with a US money order or Paypal. Paypal is the quickest as we can ship the same day as payment is received which is normally the day the repair is done.
Turnaround time is typically 2-4 days.
If you decide to use Paypal please use our email address as the recipient. You may also pay with a money order.
Regards,
Stephen Mantz
Zed Audio Corporation
743 Cochran Street,
Suite D
Simi Valley
CA 93065
Ph # (805) 526-5315
**** so the ratings on the website u lined means it put out 242RMSx2 but is that like all four channels usually would say x4 do kinda confused
no thats a 2ch in the review, im sorry for the confusion... i was simply showing how underrated this RF lineup is. mine is rated at 100x4 but by looking at that review one can see that you can easily get 20-30% more power than its rated at.
this is the T600-4
i don't know about the older ones, in the review the reviewer says its as strong as their older amps only smaller. RF is known for underrating their amps as we all know.
so it is 242RMSx4 @4ohms stronger than the t800.4 power series older ones
i dont think it does 242x4, your merging the t600-2 and the t600-4 together
the 2ch in the review does 242x2 but thats a 200x2 rated amp so thats 20% more than specs, capish??? lol
soooo if this one (MY 4 CHANNEL) does 20-30%
it would be 120-130watts x 4 or as according to RF 139 watts x4
lucas569
lucas569
ct
lucas569
