Rockford Fostgate P1000 25 to Life 5Ch - 1400W
pardegt
I've decided to part with my RF Power1000 amp...hard to find these. Had it in my other truck before I sold it running 2 12" daytons and my comps. Sounds great and stays constantly cool. See birth sheet for specs. Comes with everything including remote as shown in pics. It has a little surface wear but could be buffed back to new if your mounting it in plain sight. There is a crack in the black plastic next to the gain control (see pics) but is hidden when cover is in place.
1400W Total RMS Power, '25 to LIFE' Special Edition Staggered 5-Channel Amplifier
Class bd Subwoofer Channel/Class AB Main Channels
RMS Power Output:
4 ohms: 50W x 4 channels plus 300W x 1 sub channel
2 ohms: 100W x 4 channels plus 600W x 1 sub channel
1 ohm: 150W x 4 channels plus 800W x 1 sub channel
Bridged rating for front/rear channels:
4 ohms: 200 watts x 2 channels
2 ohms: 300 watts x 2 channels
Built-in Variable Crossovers:
Front/Rear Channels 1-4: Variable 40-400Hz, 12 or 24db/octave Linkwitz-Riley High- and Low-Pass Crossovers
Sub Channel 5: Variable 32-250Hz, 24dB/octave Linkwitz-Riley Low-Pass Crossover. Also has a subsonic (infrasonic) filter at 28Hz fixed.
Crossovers all use 24 dB/Octave Linkwitz-Reilly Crossover Alignment
Frequency Response:
Front/Rear Channels 1-4: 20Hz to 20kHz +/- 0.5 dB
Sub Channel 5: 20Hz to 250Hz +/- 3dB
Bass Boost: 0dB to +18dB @ 35-75Hz (sub channel 5 only)
1 Ohm Stereo/2 Ohms Mono Stable
Wired Remote Para-Punch Bass Control
Removable Connections Shroud
5-channel Level Monitors
Chrome Shroud Cover
Power Meters
Indicator Lights
1/0 Gauge power/ground connectors
Built-In ANL Fusing
Cast aluminum heatsink
RCA pass-thru
Stealth Connections
*****-ana (TRANSconductance Active Nodal Amplifier) design simplifies the input circuit path for transparent and uncolored sonic performance.
MEHSA (Maximum Efficiency HeatSink Application) yields up to 5 times better heat transfer from the Mosfet devices to the heatsink.
Focused Mass heatsink for increased efficiency and reduced distortion.
3-Stage Variable Forced Convection cooling for superior heat dissipation and maximum protection.
Custom designed TO-247 output Mosfets have 60% more metal tab area for improved thermal stability and wider linearity.
Military Specification (Mil Spec) Glass Epoxy circuit boards accept larger copper traces for better current flow and resist vibration much better than inferior fiberglass circuit boards.
Does not include Snap-on tool.
Dimensions: 23"L x 12-3/4"W x 2-5/8"H
$475 + shipping (paypal please)
View attachment 26554016View attachment 26554013View attachment 26554015View attachment 26554014View attachment 26554017View attachment 26554018
pardegt/11-27-15
pardegt
pardegt
Midwest
pardegt
