rockford fosgate p500.2
im not sure if thats wat he is tryin 2 do. i drew up an idea but im not sure if it will work, ill try 2 put it on here. n he has a mitsubishi galant wit a huge trunk
3827828926
. im not sure if this pic is gonna work. ya they r gonna b in a ported box.
ya i figured that. but he said he can get another p500 for really cheap. since each sub has 4 terminals can we run one amp to 2 terminals on one sub and run the other 2 to the middle sub then do the same thing on the other amp so all the terminals are used? basicall run 2 amps to 3 subs...
save a sub (use 2) for when he blows up 1 from not knowing wth he is doing:p:
LOL only time people hook their stuff up like you are talking about is for short burps for SPL contests and those amps are not made to for SPL contests. You would chance running into too low of impedance or too high over time to get the power to the subs (lower watts). With the 1 shared sub between both amps you would have to use a DMM to balance the amplifiers gain so the output would be equal. You do not set it right you can damage the "shared" woofer. You alsoneed to know the subwoofers impedances.
ryanjacobs13
ryanjacobs13
H-Ville, OK
ryanjacobs13
