mono amp vs. 2-channel
scooby84
Ok I hate sounding dumb but the only way to learn is to ask questions. What is the difference between say a 2 or 4 channel amp, and a mono amp. I imagine that a mono amp is a 1 channel amp, right? But if that is the case, why do I have a mono amp with 4 speaker connections. They go like this --++. I am able to hook 2 subs up to it. But if it is just 1 channel, how is that possible. This confuses me. Also, what would be a better amp to get for 2 subs. Another mono amp like the one I have, massive audio p1000.1, or a 2-channel amp?
They do this to allow more headroom for wire so that you are not bunching up a crap ton of subwire into 2 terminals.
It is still a mono amp just an extra set of + and - terminals.
Also you can run any amount of subs off any amp if you know how to wire them to stay with in the amplifiers recommended impedence.
This wire diagram site will help you. Use it.
http://www.the12volt.com/caraudio/woofer_configurations.asp
mono amps are generally class d amps which are more efficient but do not cover as much of the sound spectrum as the less efficient class ab amps do. Multi-channel amps are usually class ab.
scooby84
scooby84
Radcliff, KY
allout13
