ROCKFORD FOSGATE 3SIXTY.2 SIGNAL PROCESSOR brand new
mclerico83
tampa
brand new
250 shipped
included
I'm aware there is a 3sixty.1 and a 3sixty.2.....but there is a v1 and v2 of the 3sixty.2 ....the v1 had Bluetooth issues....it should tell you on the barcode if it's v1 or v2
ok its a v2 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif says it directly on the unit
Is not "new in box". Move the camera down one line and you would have seen "factory refurbished". Was refurbed and then used. There is no bracket to mount the remote knob as it was apparently left in the new in box installation it was pulled from. Hopefully it works.
it cam in factory box. I ordered it off ebay as a refurb brand new open box never used. all the wires etc have never been cut or anything. I bought it for my saab 9-3 with bose but am now going through personal problems and will not be able to do the install. If you want a refund thats fine we can work something out or i can pay for mounting brackets if they are missing "idk" whats suppose to come with it.
https://www.google.com/search?q=rockford+fosgate+sixty.2&espv=2&source=lnms&tbm=isch&sa=X&ei=UzurU_vEGNOyyASziIHwAg&ved=0CAgQ_AUoAw&biw=1366&bih=667#facrc=_&imgrc=7UBE4iFfT6jGVM%253A%3B3wjZxfsLSBy02M%3Bhttp%253A%252F%252Fwww.rockfordfosgate.com%252Fimages%252Fproducts%252Farchive%252F3Sixty2_1_l.jpg%3Bhttp%253A%252F%252Fwww.rockfordfosgate.com%252Fproducts%252Fdetails%252F3sixty.2%3B600%3B554
every image isee there are no mounting brackets.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
mclerico83
mclerico83
tampa
mclerico83
