Sold Rockford 700X 4 Channel Amp
remhunter
I have a Rockford 700X 4 Channel Amp that is in excellent shape (very little use) with end caps, boost knob, and box for $180 + shipping. I have lots of ebay feedback under "remhunter". Email me if you'd like pics.
jeffneuschwander@yahoo.com
Here are the specs:
- 87.5 watts RMS x 4 at 4 ohms
- 175 watts RMS x 4 at 2 ohms
- 350 watts RMS x 2 at 4 ohms in bridged mode
- 2, 3, or 4-channel output
- Tri-Way capable
- Front and rear high-pass/low-pass crossovers (variable 50-210 Hz, 12dB/octave)
- MOSFET power supply and output devices
- Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
- TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
- *****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
- NOMAD — advanced protection circuitry for "intelligent" shutdown protection
- Speaker- and preamp-level inputs
- Punch Bass boosts bass up to 18 dB at 45 Hz
- Dimensions: 18-1/2"W (14-13/16" without endcaps) x 2-7/16"H x 9-7/8"D
remhunter
remhunter
Oregon
remhunter
