Sold Rockford 501X
alpinetypeR
NY
501X Rockford amp...
* 65 watts RMS x 4 at 4 ohms
* 125 watts RMS x 4 at 2 ohms
* 250 watts RMS x 2 at 4 ohms in bridged mode
* 2-, 3-, or 4-channel output
* 4-ohm stable in bridged mode
* Tri-Way capable
* requires 8-gauge power and ground leads wiring and hardware not included with amplifier
* front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
* MOSFET power supply and output devices
* Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
* TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise
* Transana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
* NOMAD advanced protection circuitry for "intelligent" shutdown protection
* speaker- and preamp-level inputs
* preamp outputs
* 12-1/16"W x 2-3/8"H x 9-7/8"D
100$+shipping
any scratches, dents, dings? amp in 100% working order? anything broken wit the knobs? missing screws?
missing center rockford sticker... not really any scratches....
last time i had it plugged in work 101% //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
missing nothing, no broken knobs.
alpinetypeR
alpinetypeR
NY
RegalBoi97
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
