right input half working?
goingdef
well I was just messing around in the trunk and thought I haven't pulled the rca's off this mojo2000d and tested each input yet, well d@mn the right one barely has any output I plugged up to the right output and it plays fine, I'm guessing it's just the rca plug it's self not making contact on the outer portion because I plug the rca in I hear a faint signal? anyone else ever had this happen and did you fix it or just use the output side as there the same plug?
let me know. im rebuilding as well
well I got it apart and it doesnt look serviceable but easily replaced though, so I guess it's run the line-outs for inputs as they look/work like new and I never used them anyway.
well wasn't this an adventure just to realize when the rca is turned/spun just right it quits, all of that "f"in around just to realize I need to run a new set of rca's, and to boot the other set I had laying around are shorted in the same place d@mn it. well off to ebay to order a new set.
goingdef
goingdef
Norfolk VA
goingdef
