Kingstroker
Mr Dique
just got my amp back and along with it I installed a new set of Monster RCA's. Ran a direct ground to the battery from the HU as per Pioneer instruction because of clicking or popping sound when I switched functions or powered on/off(didn't work). Everything when well until I screwed the HU back into the dash, back out of the shop and turned it on. It made some real snap, crackle, pops and buzzed then stopped. After that it was okay but I quikly turned it off a pulled the amp fuse. It was late so didn't do anything else. It didn't do this before it pushed the HU into the dash and put everything back together. Could I have pinched a wire? I also got a little rain in my cab a month ago, could my ground be a little corroded? It is under carpet and pad that got wet. If it wasn't 19 degrees right now I would pull it apart and check it out.
