RIAA up to something?
kombat96
In an obvious protest against pirating music, someone has unleashed a new, low threat trojan virus onto the Internet community that is hellbent on deleting all of your MP3 files. Known as the W32.Deletemusic, this virus does exactly as the name implies. Once activated, it will scan any drive connected to your PC and delete any music file, whether it be on your primary hard drive, flash drive, or external hard drive. Additionally, it'll attach itself to an infected drive and if that drive is inserted into another machine, it will again continue its destruction of all your music.
This isn't the first time some group has taken its aim on pirating. Over the past two years, there have been other trojans named Nopir-B and Erazer. The latter being the more vicious of the two as it wouldn't only target mp3s, but AVI, mpgs, wmvs and ZIP files.
While speculation can point this towards an RIAA cooked up trojan that thwarts would-be pirates, analysts claim that this type of thing appears to be the work of mischievous teenagers and not some larger entity.
W32.Deletemusic affects computers running Windows all the way back from Windows 95 to Windows Vista and everything in between.
The worm was discovered on July 30 and also goes by the name of W32/Deletemp3.worm and W32/DelMP3-A. It is also capable of infecting Windows 95, 98, Me, NT, 2000, Server 2003, XP and Vista. Currently classed as Risk Level 1: Very Low on the Symantec website the worm spreads via removable flash drives. If autorun is enabled when you insert a USB flash device then the worm copies itself to your machine and then creates an Autorun file to ensure it continues to run every time the user boots.
Speaking of the risk factor imposed by the new worm, senior consultant for Sophos, Garham Cluley has the following to say:
“it’s not something we would lose an awful lot of sleep over, but there are some lessons that computer users should learn to minimize the chances of infection”
To make your PC safer Cluley suggests disabling the autorun feature on your machine as both DVD and USB drives use this feature and it can help the spread of malicious software such as this.
Just dont buy it? //content.invisioncic.com/y282845/emoticons/imdaman.gif.bc6c552e19aa4ad8c47461144f40eb1a.gif
Yeah, lesson learned. Don't pay for music, steal it instead so when it disappears, you don't lose your money.
I'm gonna blame my downloading habits on the trojan.
San Francisco (IDGNS) - Security experts have discovered a worm that might just be the recording industry's dream application: it hunts down and deletes MP3s on infected PCs.
ADVERTISEMENT
Security companies say the worm is only low risk, although its unusual payload could give a nasty surprise to an ardent music fan. The motivation of the hackers who created it are unclear.
"The authors of this worm are more likely to be teenage mischief makers than the organized criminal gangs we typically see authoring financially-motivated malware these days," said Graham Cluley, senior technology consultant for the security vendor Sophos.
"As such, it's not something we would lose an awful lot of sleep over, but there are some lessons that computer users should learn to minimize the chances of infection," he said.
The worm spreads via removable flash drives, reminiscent of the way viruses spread via floppy disks decades ago. That may be an attempt by the authors of the worm to bypass e-mail filters and Web gateway filters that block malicious software, Cluley said.
Symantec, which calls the worm W32.Deletemusic, said in an advisory that the worm copies itself to all drives on a PC. It also creates an autorun file to start itself whenever a user accesses a drive.
The worm affects PCs running Windows 2000, 95, 98, Me, NT, Server 2003, XP, and Vista, Symantec said. Users could disable the autorun feature in Windows that automatically launches programs on CDs or USB drives, Cluley said.
It's not the first malicious software to go after music files. Two years ago, researchers saw the Nopir-B worm, which posed as a utility to make copies of DVDs. Once on a machine, it displayed an anti-piracy graphic and tried to delete MP3s and other files.
Last year, a Trojan horse program called Erazer took the destructive activity a step further, wiping out MP3s as well as movies, Cluley said.
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
1. Disable System Restore (Windows Me/XP).
2. Update the virus definitions.
3. Run a full system scan.
4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
* How to disable or enable Windows Me System Restore
* How to turn off or turn on Windows XP System Restore
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
* Running LiveUpdate, which is the easiest way to obtain virus definitions.
If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
* Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
2. Run a full system scan.
3. If any files are detected, follow the instructions displayed by your antivirus program.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
1. Click Start > Run.
2. Type regedit
3. Click OK.
Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
4. Navigate to and delete the following registry entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce\"Worms" = "C:\WINDOWS\system32\logon.bat"
5. Restore the following registry entries to their previous values, if required:
HKEY_ALL_USERS\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\"NoFolderOptions" = "1"
HKEY_ALL_USERS\Software\Microsoft\Windows\CurrentVersion\Policies\System\"DisableTaskMgr" = "1"
6. Exit the Registry Editor.
hmmm, sucks!!!
Thanks for the info though, posted a bulletin to warn those who have not seen the light of caraudio.com //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Any decent anti-virus will catch this not to mention you'd have to be an idiot to catch it in the first place.
I guess if you're a complete retard who 1) can't research anti-virus software and 2) can't research what you're downloading, then yay for Macs ... Otherwise, for the rest of us who aren't retarded, this doesn't matter ...
but we're talking about ca.com
yay macs
kombat96
kombat96
michigan
Chevillac
